Drawing with snapping
SmartCursor snapping allows you to draw with precision in Top/Plan or 3D views. Used in conjunction with drawing tools, the SmartCursor uses snap indicators, hints, extension lines, text (SmartCursor cues), and sounds, and then precisely snaps the cursor based on the snapping types enabled in the Snapping set.
Setting snapping parameters
Snapping techniques
SmartCursor cues
